I have the Edge Attitude/Juice. If I go with EFI will the guages still read true on the Attitude, i.e. boost, intake temp, load, etc? I have a boost controller that definatelly messes up the boost reading. When not using the controller, the boost is very accurate to the guage. I'd consider selling the Juice adn just keeping the Attitude for its PID capability and reset capability on teh fly, 0-60 and 1/4 mile, etc. It has a nice tidy look to it.
How quick is it to change programs? I.e. I get off work and need to uninstall a race/play tune and install an EGT friendly tow tune.
I sure hope they develop a power switch on the fly setting for this.
If the guages don't display correctly with EFI, just the standard Boost/EGT should sufice correct since the trans is displayed on the dash.
EFI allows you to control the boost also correct? I.e. I got the boost controller to add more boost for keeping the egt down. I can design a egt friendly program is what I'm after.
Thanks all.
How do you get other people's programs? Typically buy them? Or is there a sorce for free ones for the LBZ?
Help discribe the programing process please:
I think:
1) Use EFI 7.3.3 soft ware on computer to make programs.
2) load into Flash scan (Calculator looking thing) and plug this into your OBD port?
What is FlashScan V2 Scan only and Flash Scan V2 Tuning?
Scan only logs data onto it and you load onto your computer for analyzing?
Tuning allows you to take the data on your computer put there from the Scan tool and change it/program to your liking and then put it back into the truck for more HP?
I get the feeling the scan tool is to replace a computer?
Confused on how all this ties together.
