Results 1 to 6 of 6
Thread: Problem with Trailblazer scan data.
    Default Problem with Trailblazer scan data.
    Last week I had a guy in for a baseline of his 06' Trailblazer SS. Because I didn't have the current version .555 I was unable to gain access to the BiDi controls I needed to lock the trans for a pull. Well I downloaded the new version in which it appeared I would be able to communicate with the correct controller. No deal! After some inquiring it sounded like Live V2 still does not allow BiDi control with the T42. Can someone please clarify this? I was embarrassed last night when the guy came back to try it again and it didn't work. I even tried to raise all the down shift MPH to 314 and it still down shifts under load. Which trans is this?? 4L70E?
    I also noticed as it the scanner was on that the injector duty cycle at idle was 243%!
    What's the problem?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Yep, they have the E40 ECM and T42 Trans controller for a 4L70E (06 only, 07s use the E38 ECM).
    Quote Originally Posted by ScarabEpic22
    Can someone tell me for sure if BiDi controls work on the T42 trans controller?
    1-954-703-5560
    I dont know, I can ask someone that might though...
    Oct 2004
    This functionality does not currently exist, and is likely to be first seen in version 8 later in the year.
    Andrew
    EFILive Crew
    Guess not then...
  1. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 18th, 2008, 12:05 AM
  2. Scan Data vs Tune maps? HELP
    By Wichita Dyno in forum Gen III V8 Specific
    Last Post: September 25th, 2007, 05:48 AM
  3. Converting Scan data
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 8th, 2006, 10:41 AM
  4. linking scan data to tune file
    By a78turbo in forum Duramax LLY
    Last Post: March 14th, 2006, 04:53 PM
