Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Easiest Way to compare tables
    Dec 2005
    Default Easiest Way to compare tables
    Just want some tips on comparing tables, I suppose 2 screens would be the best, the Alt buttons are handy, tryed to print by edit > paste but it printed in Hex.
    Can they be printed somehow
    04.5 GMC 2500HD SLE D/A 4wd ExCab Shtbox Blue
    Lifetime Member johnv's Avatar
    Jan 2005
    If the same operating system just use "load alternate file" tab and and use the compare functions to show differeces or similarities.
    The sumery of differences you should be able to copy and paste to note pad or word etc for a hard copy.
    To copy changes from the compared file, just highlight the calibration in the summery window and click on the update tab.
    If different operating systems you will have to open a seperate window and visually compare,but you can still copy from one and paste to the other.
    Dec 2005
    If I'm looking at a stock table and a modified table and I want to change some of the areas of the modified table, if I had 2 screens I'd be looking at the mod table or stock on 1 screen and writing my changes on the other (I haven't got 2 screens).
    If I could print the tables out would help - can this not be done?
    I have printed out summaries, histories etc.
    Thanks.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Actually, I'm interested in this too.
    There is nothing like having a "hard" copy in front of you to work off of.
    I also have problems with comparing tables from two different operating systems where you cant use the ALT comparison function.
    Looking through some of the posts in this forum I see people attaching screen shots of their tables.
    What are you guys using to create these screen shots?
    If I could create my own screen shots, I would be able to print them out.
    Dave.
    Oct 2005
    Quote Originally Posted by Biggsy
    Dave.
    One method: Hit the "Print Screen" key, open MS Paint>Edit>Paste. Then edit as desired and "Save As" in your preferred file format to your preferred location.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Sep 2005
    All you have to do to capture screen images and print them is to hit the print scrn button, then open MS paint and paste it in there. Then you can crop as desired and then print out a hard copy. If you want to post the image, after you crop it in MS paint, save it as a JEPG and upload it to a site like photo bucket and then insert the link from Photo Bucket into your post. HTH
    Jan 2007
    It worked!!!! Amazingly simple, thanx for that guys!
    Dave.
    Dec 2005
    Yeh managed to get it to work, Thanks
    When V 8 comes out it will have print function built in, at least for history etc,
    Another option for comparing tables is to copy/paste to Excel (if you have Excel).
    When you select a range of cells and right click and selct "Copy with labels", EFILive creates a clipboard copy of the data that is compatible with Excel. You can then just paste the data into Excel and it will be formatted into the Excel spreadsheet ready for any type of manipulation, comparison and even printing.
    Hint: to select the whole table, click in the top-left, blank, grey cell. (click in the table and press Ctrl+A).
    Biggsy, more info: showthread.php?t=3064
  1. Compare feature
    By purrvert in forum Custom Operating Systems
    Last Post: May 25th, 2007, 09:11 AM
  2. Easiest Plug N Play WBO2 for LS6?
    By NewV in forum Gen III V8 Specific
    Last Post: December 4th, 2006, 05:07 PM
  3. Cant compare files.
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2006, 01:42 PM
