Results 11 to 20 of 21
Thread: Easiest Way to compare tables
  1. #11
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Biggsy, more info: showthread.php?t=3064
    Thanx Joecar, I missed that one in the search
    Looks like you are a valuable asset to the group! I like your pictorial explainations, they will help lots of people.
    Dave.
  2. #12
    Quote Originally Posted by Biggsy
    Dave.
    Dave, thanks; I understand pictures better than words.
  3. #13
    Jan 2007
    Just giving credit where it is due
    You can explain a whole heap more with just one picture, as the saying goes :
    A picture is worth a thousand words............
    Dave.
  4. #14
    Dec 2005
    Quote Originally Posted by Kiwi Ed
    If I'm looking at a stock table and a modified table and I want to change some of the areas of the modified table, if I had 2 screens I'd be looking at the mod table or stock on 1 screen and writing my changes on the other (I haven't got 2 screens).
    If I could print the tables out would help - can this not be done?
    I have printed out summaries, histories etc.
    Thanks.
    I have read about people using 2 screens, I take it you would open EFI twice, & what all would you need to hook them up.
    04.5 GMC 2500HD SLE D/A 4wd ExCab Shtbox Blue
  5. #15
    Oct 2005
    AFAIK you can open multiple instances of the tuning tool when working with different OSs, but you can't actually link them. You can copy and paste values from the tables between them, but not entire segments.
    If you are just dealing with a single OS, you can just load the alternate tune as described above and toggle back and forth between the two. Or if you want to look at both side by side you can open a second instance of EFILive and adjust the window sizes so that both will fit on your screen.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
  6. #16
    Member bK's Avatar
    Mar 2004
    If you have the luxury of 2 monitors running off your computer, I found this very easy to compare tunes from different OS's. 1st screen with 1 copy of EFILive Tuning and the 2nd screen with a different copy of EFILive tuning.
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
  7. #17
    Dec 2005
    Quote Originally Posted by DrX
    How do you this
  8. #18
    Dec 2005
    Quote Originally Posted by bK
    Is any thing special needed to do this ?
  9. #19
    Oct 2005
    How do you this
    Open 2 instances of the Tuning Tool.
    Click on the "Restore Down" button(green arrow).
    Click(and hold) on and drag the borders of the windows around until they are sized as you want them.
    Click on the top bar to drag the entire window around.
    Just click on whichever window you wish to bring to the top.
    You can do the same thing with the table windows themselves to resize and reposition them.
    You can also drag the frame borders within the Tuning Tool to resize them.
    Here's an example:
    For dual monitors you will require a video card with dual outputs and an operating system that supports this(e.g. XP).
  10. #20
    Member bK's Avatar
    Mar 2004
    Using either a computer with 2 video outputs or a laptop with an external monitor, setup the 2nd screen as an extension of the 1st screen not as a copy (same image on both screens)
    Open 2 copies of EFILive Tune, drag the 2nd copy to the 2nd screen. And you should have a screen that looks like this.
    Chassis by Holden
    Engine by Chev
    Cam by Comp Cams
  1. Compare feature
    By purrvert in forum Custom Operating Systems
    Last Post: May 25th, 2007, 09:11 AM
  2. Easiest Plug N Play WBO2 for LS6?
    By NewV in forum Gen III V8 Specific
    Last Post: December 4th, 2006, 05:07 PM
  3. Cant compare files.
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2006, 01:42 PM
