Got a weird problem.
01 truck tuned in SD 2 bar. Truck runs fine for 30 or so miles then truck goes into a limp mode. There is no codes other than the MAF which is there all the time.You can not reset the computer to get it out of limp mode.The computer needs to be reflashed(partial with EFI live) and runs perfect again for another 30-40 miles and goes out again.After it goes into limp mode the battery light will go on/off but the voltage stays at a steady 14volts.
Anybody have this problem? I'm thinking the computer is junk.
Also the truck has a new battery and altinator. When we got the truck the altinator was burn't up from a loose power wire which melted back a bit.
Don
