i just got the RR .... there is no other hardware that came with it exept the two usb cables, is the bluetooth built-in inside the case???
Bluetooth adapter is purchased separately, plugs into RR
Dave.
oh ok so do you have to get it from Moats or just from any computer store...do you have a link to a good one
You have to get the Bluetooth from Moates. It is a adapter then goes on the RoadRunner like the USB cable. Basically it is a special item
Andrew
EFILive Crew
thanks guys ill check out the Moats website..
