Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: i hear detonation but can't see it
    Oct 2005
    Question i hear detonation but can't see it
    Hello guys ,
    How can I know if the knock sensors are lazy ??
    I have this, Chevy CAMARO that I'm trying to tune. Everything is fine on the DYNO but when I went out for a road test it hit me !!!
    The dam engine is detonating like hell …. I can hear it so clearly when I put the windows up ( low RPM part throttle – high RPM WOT )!!!!
    The problem is I can not see anything on my scanner it shows 0° of knock even if I melting the engine !!!!
    Please look at the file and tell me if I'm doing anything wrong ?
    Thanks for your help guys
    Oct 2005
    Here is the scam for that same vehicle with the same tune .
    As you can see there is not a single detonation that was deducted !!!
    As I said you can clearly hear that detonation under load with the windows closed .
    I thought for a moment that it was filed detonation . I added 4 liters( one gallon ) of C16 to a half full tank and the car was running like crazy with not a single det that I've heard . That makes what I was hearing for sure is detonation before the C16
    Hope this helps you to help me
    ASSAMI,
    Several things from looking at your files:
    - looks like there is too much spark advance for a 2002 F-body;
    - IAT settles to 38C/100F after car is going, so the ambient air is hot (where are you located...?);
    - LTFT's are zero throughout, running OL, do you know the AFR...?
    - MAP sensor hits 95 kPa at WOT, does this match your elevation...?
    - Injector duty cycle hits 90%, it's getting close.
    The knock sensors may not hear all knock, and they do degrade over time;
    also, changing engine internals may move the knock resonant frequency.
    Mar 2005
    It looks like several changes have been made to the Knock and the Knock-Software settings. You might trying resetting to stock and start over to see if it knocks with those settings. I think some of your spark curves could use a little reworking and it would improve driveability after you find your no-knock problem.
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Check out the TPS. It stays on "0" until he's up to 85 mph!
    Of course, that doesn't have anything to do with your problem but a few PIDs are based on throttle position.
    Quote Originally Posted by johnsZ06
    I didn't see that one... yes, that's very important.
    Sep 2003
    You should pull some of the timing as well. No need to go over 40 degrees on an LS1 at cruise.
    Oct 2005
    joecar:
    - looks like there is too much spark advance for a 2002 F-body; (( I JUST WANTED YOU PEPOLE TO SEE THAT THE KNOCK IS NOT HEARING ANYTHING IT IS DOWN 5D NOW))
    - IAT settles to 38C/100F after car is going, so the ambient air is hot (where are you located...? (( SAUDI ARABIA THE OUTSAID TIMP IS 29c ))
    - LTFT's are zero throughout, running OL, do you know the AFR...? (( ON THE DYNO IS 12.8 AT MAX TORQ AND 13 UP END ))
    - MAP sensor hits 95 kPa at WOT, does this match your elevation...? (( SEA LEVEL ))
    - Injector duty cycle hits 90%, it's getting close. (( YES THANKS ))
    The knock sensors may not hear all knock, and they do degrade over time;(( CAN YOU EXPLAIN ))
    Also, changing engine internals may move the knock resonant frequency.(( THE CAR CAME WITH AFR 64cc AND A SMALL CAM. DOING 362whp ))
    Oct 2005
    Quote Originally Posted by RonC
    I DID…. ITS ALMOST THE SAME L
    Oct 2005
    CANT SEE IT ? WHAT ARE U TALKING ABOUT !!
  1. Detonation After Tramsmission Tweaks
    By therock in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2009, 10:21 PM
  2. Lean Cruise without detonation
    By cmitchell17 in forum Tuning For Economy
    Last Post: April 27th, 2008, 09:38 AM
