Is it possible? If I select the one frame I want to get rid of the deletion button does not turn on, but selecting 2 frames or more it does.
Looks like you cannot delete one frame :(Originally Posted by dbaxter_ss
I will try and fix it.
The enable criteria for deleting frames was "only if a selection was active". A selection is only active when 2 or more frames are highlighted.
The Scan Tool now allows a single frame to be deleted. If no selection is active and the delete button is pressed, the current frame is removed.
The new version should be available before the weekend.
Sweet
