Results 1 to 6 of 6
Thread: Auto VE setup with CO 3
    Lifetime Member johnv's Avatar
    Jan 2005
    Default Auto VE setup with CO 3
    Haven't done any auto VE tuneing with CO3 before, done a few mods and would like to check the tune.
    OK the tutorial gives a setup for table {B3605} which does not exist in CO3, so I take it we need to modify table {B3647} instead, op sys does not have {B3649} (01290003)
    So how do we set up {B3647} for auto VE ?
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    set it to anything other than 1.00 (EQ) or 14.63 (AFR). Mine is a little agressive, but i was aiming for a nice smooth transition from vacuum to boost. My PE is set to 11.65 AFR from 2400RPM and higher. Here is how my 3647 looks....
    2014 GMC 2500HD RCLB SLE
    LML / Allison
    Jan 2005
    Do you have it set up like this in your auto VE tune file as well as your final tune ?
    Just after a safe setup for the Auto VE process as PE {B3618} is set at 14.63 as per tutorial.
    Sep 2006
    Quote Originally Posted by johnv
    I am going to stay in SD open loop, so this will be my final tune.
    I am trying to AutoVE my boost areas as well, so i dont want my B3618 to be 14.63 otherwise I might go boom. Can you post some details about your vehicle? Are you boosted?
    LML / Allison
    Jan 2005
    Quote Originally Posted by Whippled 496
    Just heads and cam ,and all boltons at moment, but 3/4s of the way through a single turbo build.
    14.63 is way to lean for my WOT stuff aswell.
    in a std operating system safe AFRs are set up in {B3605} for the purpose of VE tuneing, but this table does not exist in CO3.
    So do we put safe figures in {B3618} and use PE or modify {B3647} to give safe AFRs at WOT for the purpose of dialing in VE ?
    Jan 2005
    The purpose of B3647 is to allow you to command the mixture you want for any given RPM/MAP. The table Whippled posted appears to be a safe starting point.
  1. RR Setup
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 12th, 2009, 03:25 AM
  2. LC1 setup for e85 ?
    By yellowC6ohio in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2008, 04:11 AM
  3. Pic of my setup.
    Last Post: September 13th, 2005, 09:45 AM
  4. What is the best way to setup PE VS RPM?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2005, 03:33 PM
  5. 2 bar map setup
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2005, 04:39 PM
