Results 1 to 6 of 6
Thread: ETC reaction time
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Question ETC reaction time
    G'day guys,
    I was driving my boss's VZ V6 Commodore ute today and noticed the ETC was slow in reacting to my pushing of the throttle. There is quite a significant delay between planting your foot to when the revs pick up.
    My question is, does the ETC on a LS1 have this same delay in reaction time, and is there anything you can tune to reduce this delay?
    Dave.
    The delay is lack of power in that car
    They seem to be pretty responsive, unfortunately the TAC module on the Holden doesn't sit to well when you alter the ETC response tables. Most of the US vehicles got lucky and they can alter the ETC response.
    Cheers.
    Jan 2007
    Where are the ETC response tables you speak of?
    Dave.
    You won't see them unless you have FlashScan V2, or FlashScan V1 with a Commercial or Workshop license. Even then, you won't see them unless your cable is plugged in prior to starting the software. They will show up with a red icon in the navigator.
    Oct 2006
    ahhh, the cable has to pluged in. I was trying to figure out the other day why i could change those settings when i was in my truck and not when i was reading logs in my house and changing things. thanks man
    Jan 2007
    Thanx Paul!
    I thought I had seen the little red folder before! I was begining to think the ETC options were removed from the latest version.
    I will plug my cable in and have a look
    EDIT: Yep, it appears
    Is there anything else that doesn't show up without the cable plugged in?
    What is the reason for not showing it without a cable?
    Dave.
  1. P0101 ...wanted delay in MAF reaction
    By ar99kid in forum Gen III V8 Specific
    Last Post: December 23rd, 2009, 12:12 AM
  2. Injector Reaction Time - Effect on Timing?
    By VegasDMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 6th, 2009, 04:52 AM
  3. 1 more time
    By justin123 in forum Gen III V8 Specific
    Last Post: May 3rd, 2009, 12:21 PM
  4. PE vs RPM vs Time?
    By Highlander in forum Gen III V8 Specific
    Last Post: August 22nd, 2008, 02:12 AM
