Results 1 to 4 of 4
Thread: Finally Installed Headers, got a few codes 2 days later
    Nov 2006
    Default Finally Installed Headers, got a few codes 2 days later
    Last weekend, I finally got to install my headers on my 99 f-body. I followed a link here to a great post about want o2, egr and air codes to turn off.
    2 days later, it throw a few codes I was not sure about...
    There are repeated 3 times, once under EPA, once under EPA pending and once under MHC.
    P0134 o2s circuit insufficient activity bank 1 sensor 1
    P0155 o2s heater performance bank 2 sensor 1
    I am assuming these are the front o2s and I did not just miss tuning something out on the back ones.
    Any suggestions on what I need to do?
    Mark
    Junior Member JET LEE's Avatar
    Jan 2007
    So....I'm assuming that you disabled the rear ones?
    You ran two days without throwing codes after disabling the rear ones?
    Did you get the error codes all at once or at different times?
    I may be totally off base but I would make sure that you haven't burned the plugs or wires on those 02's....just a suggestion. I'm saying this because I burned a plug on one of my rear ones and got similar codes, before disabling them.
    Nov 2006
    Quote Originally Posted by JET LEE
    Yeah, not codes until well into the second day of driving. Rear o2's are disabled. Soon as it cools down I will have to take a peak at the connections, hopefully it is that easy. I do have a set of vette o2's coming also.
    Mark
    Lifetime Member johnv's Avatar
    Jan 2005
    o2s are probably running cooler with the header install, may need to move them forward a bit .
  1. Injecters and headers installed! do i need to change tune?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 5th, 2009, 07:31 PM
  2. Installed headers wont run in CL
    Last Post: September 18th, 2007, 01:42 AM
  3. Headers installed tomorrow what should I expect?
    By NewV in forum Gen III V8 Specific
    Last Post: September 17th, 2007, 04:33 AM
  4. is it a couple of days yet?
    By limited cv8r in forum E37, E38 & E67 PFI ECM's
    Last Post: July 2nd, 2007, 07:11 AM
