Results 1 to 9 of 9
Thread: smoke tune
    Jan 2006
    Default smoke tune
    Is there a way I can make my truck just blow black smoke and not make a bunch of power where it will destroy the tranny? Im installing dsp2 this week and wanted to use the switch for the smoke tune. I have a 03 dually with straight pipe if that matters.
    Senior Member lakingslayer's Avatar
    Dec 2005
    Remove boost and timing. You can add fuel. You'll need to watch the EGT's though. I recommend doing all these steps with small changes at a time.
    Feb 2007
    I am looking to do the same but not sure if I need to remove boost and timing from the stock tune or the dsp tables?
    2002 CC/LB 4x4 LT Package, stock everything with the addition of Juice w/Attitude
    Whatever tune you want it to happen in, probably one of the DSP tunes would make more sense.
    New Member duramax1861's Avatar
    Aug 2011
    how do i remove both boost and timing? im new to the whole efi live.
    2005 GMC 2500HD LLY R/C Longbed with banks 4 inch turbo back exhaust, banks intake, egt and boost pillar gauges and efi live by Nick at Duramaxtuner.com
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    with a lb7 we do not have a vvt to work with so boost settings wont do anything... if you want a tune that blows a bunch of smoke has near no power and runs very high egts you can set the tune up to have fueling (2300pw would be enough) and set all the timing past 70mm3 to say 0...lol this will make smoke. OR if you would just like to have more smoke mainly on spoolup you can go into you maf flow rate (under airflow) and go 10% up in voltages past 2. Hope this helps a little...just remember egts will be high.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Aug 2011
    ok thanks dmaxink.
    Junior Member justafarmtruck's Avatar
    Aug 2011
    did you get one if not i can make you one
    Aug 2011
    Yes I did from Nick at duramaxtuner.com
  1. LBZ smoke: Fuel Qty vs RPM-B1117 not working
    Last Post: November 5th, 2009, 04:59 PM
  2. Reducing Smoke
    Last Post: July 10th, 2009, 03:22 AM
  3. Replies: 1
    Last Post: December 9th, 2008, 02:20 AM
  4. Help, V2 causes my truck to smoke.
    By Trippin in forum General (Petrol, Gas, Ethanol)
    Last Post: November 20th, 2006, 12:37 PM
