Results 1 to 4 of 4
Thread: ? about Memory card for V2
    Apr 2006
    Default ? about Memory card for V2
    Any SD card will work correct? I found a 4gig SD at newegg.com for $39
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    I'm pretty sure it will only recognize up to 2 gig cards, which is WAY bigger, then you could ever fill if you never deleted anything from it, lol. Ross recommends a couple 512 meg cards, so you don't have to have everything on one card. Plus 1 512meg will hold tons of tunes and days of data logging. I think 1 tune in your truck is 2 meg and most data logs are a bit over a meg an hour depending on how many pids you logging.
    Apr 2006
    Ok.......I have a slight "if this is good, than this is way better" problem.......
    Sep 2005
    lol, I know what you mean
  1. Internal Memory
    By Goldfinger911 in forum FlashScan V2
    Last Post: October 15th, 2008, 06:38 PM
  2. Flash memory programming.
    By rally1 in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 07:44 PM
  3. Memory card, laptop, programer, etc...help please
    By serpa4 in forum General (Diesel)
    Last Post: February 18th, 2007, 01:15 PM
  4. Memory dump VS Commodore
    By vsboost in forum EFILive V4
    Last Post: March 11th, 2006, 03:39 PM
