Results 1 to 5 of 5
Thread: help in supercharged c5
    Feb 2007
    Default help in supercharged c5
    i need all your advice to retune my c5..., i did tune the car by ls1 edite but after 3 pcm burned ,i decide to shift to EFILIVE ,so i need your advice to start with it , the car run to rich on idle , and little lean in high rmp...???
    i guess the better way is get the back to stock file , than start tuning step by step , thats will make it more clear , isn't ?
    here my setup :
    374cid forged engine, A&A p1 supercharger @12 psi,24lb injectors,recetonix fuel pump, cam 224/228 581/588 114 , ported cam ,1.8 rockers, z06 intake , full exhaust system, 3.42 gear .yank 3200 stall ...ngk tr 9 spark plugs ,msd plugs wire , water injection...
    my last time in dyno...car was so bad and the guy on dyno was more than stupid !!! First run 540 tooooooooooo rich ,, in 2ed. run ..591 without any info.
    what do you think ?
ID:	1336   Click image for larger version.
ID:	1337   Click image for larger version.
    Jan 2004
    Didn't you just place a order for EFILive V1? First I would look at some new injectors. Either 42lb SVO or 60lb Mototron. Give me a few to take a look at the files and I'll get back with you.
    Edit - Looks like it might be setup for 42lb already. Also appears to have 28* of timing and PE Table set to 13.1
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Definetly get bigger injectors. Those are smaller than my stock LS6 injectors.
    Feb 2007
    Quote Originally Posted by Black02SS
    yes i did place a order for EFILIVE V1., i got that file from the dyno ,im already have 42lb injectors.
    Feb 2007
    here my file , from where should i start ?
  1. Replies: 1
    Last Post: June 2nd, 2010, 04:56 PM
  2. Advice:427 supercharged LS9 injector/LS7 MAF
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2010, 03:25 PM
  3. Supercharged without automatic transmission tuning.
    By scdyne in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 16th, 2010, 10:06 AM
  4. Supercharged throttle tip in question
    By Ed@Late Model Speed in forum Gen IV V8 Specific
    Last Post: June 2nd, 2009, 02:56 PM
  5. commodore VX V6 supercharged
    By Steve in forum EFILive V4
    Last Post: April 5th, 2007, 10:51 AM
