Results 1 to 6 of 6
Thread: lb7 or lly
    Dec 2005
    Default lb7 or lly
    looking to get a truck to play with witches better to modify lb7 or lly wouldnt mind going into engine modes after some other testing.being engine builder mainly.just looking for +and - of the 2
    Hard to say these days, both are putting out amazing HP numbers and aftermarket parts for both is plentiful.
    I'm pretty sure most of the LLY big players ditch the VVT in favor of a 'normal' turbo if you are going to go that far.
    LLY's did (maybe still do) have an inherent overheating problem when towing, I might be wrong, but I don't think anyone has really solved that 100%.
    Personally I would get an LLY just for the VVT, but then I also would not be pushing it to the 600Hp+ mark.
    Senior Member lakingslayer's Avatar
    Dec 2005
    The LLY you don't need to remove the valve covers to replace injectors.
    Dec 2005
    Default lly
    looks like lly it is 2005 crew cab 4*4 lly in garage looking to do some mods to test.custom operating system coming soon
    Dec 2005
    Cool! I personally love the 04.5 to 05 LiLLYs.
    Mar 2007
    With the over heating problems with the lly. I have owned 2 of them the 04.5 and a 05 dually never had an overheat problem with the 05 it had 60,000 miles on it. All hard pull miles 36,000+ pounds dont tell dot. But my 04.5 lly doesnt over heat neither but it hasnt pulled anything over 20,000 pounds maybe i have just gotten lucky i still have the 04.5 lly its still runs good 60--- but the 05 got totaled
    2004.5 lly duramax edge juice w/att efi live. 5 inch exhaust with a 6 inch chrome tip thats right chrome Ppe shim mods and a custom ported fuel rail fitting Thats all for now
    2001 dodge ram 1500 4X4 8 inch lift in the front 6 inch lift in the rear 88,000 miles on it dual exhaust k&n intake hypertech progammer nice bull dog going on ( 4 sale )
