Just had a play with RTACS pre-release V7.3.4 version ,every time I go into RTAC mode the RR update sound is turned off.Is this normal?
I have to go into properties>RR and turn it back on .Anyone else notice this minor problem.
856RWHP 408 Supercharged LS1 Holden Commodore.
I think it was turned off so that it didn't drive you nuts with the constant updates... Paul might just need to enable it again when the RTACS session ends.
Andrew
EFILive Crew
I thought that might be the case but thought otherwise as you have two options too turn it off either vol on Laptop or via the properties menu.Originally Posted by Tordne
Thanks for the reply
Better get some practice in with RTACS Darren
So you can help me with my turbo tune
