Results 1 to 4 of 4
Thread: No update sound on RTACS
    Member VT LS1 NZ's Avatar
    Default No update sound on RTACS
    Just had a play with RTACS pre-release V7.3.4 version ,every time I go into RTAC mode the RR update sound is turned off.Is this normal?
    I have to go into properties>RR and turn it back on .Anyone else notice this minor problem.
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Oct 2004
    I think it was turned off so that it didn't drive you nuts with the constant updates... Paul might just need to enable it again when the RTACS session ends.
    Andrew
    EFILive Crew
    Quote Originally Posted by Tordne
    I thought that might be the case but thought otherwise as you have two options too turn it off either vol on Laptop or via the properties menu.
    Thanks for the reply
    Lifetime Member johnv's Avatar
    Jan 2005
    Better get some practice in with RTACS Darren
    So you can help me with my turbo tune
  1. Sound?
    By ace68 in forum External A/D inputs
    Last Post: December 20th, 2019, 05:49 AM
  2. bad sound
    By justin123 in forum Duramax LB7
    Last Post: September 14th, 2009, 10:02 PM
  3. Sound like a bad WB02. Driving me crazy
    Last Post: September 20th, 2007, 12:40 AM
