I originally tried this question in another part of the forum with no responses. Maybe I'll have better luck here...
Just received my V2 Friday, checked it out and saved my full baseline OS with no problems. Then yesterday, following the Getting Started tutorial, I first successfully gathered info (PIDS) and then tried to do my first data logging. After first selecting the tab for the Dashboard, I started my engine and pressed Ctrl-M and got no response. The unit indicated that it was in USB mode but the File menu on the computer displayed both the Connect and Disconnect as grayed out (as were the buttons on the toolbar). Nothing else in the program seemed to respond at that point until after I shut off the engine and disconnected the unit.
Any thoughts??
