Results 1 to 5 of 5
Thread: Memory card, laptop, programer, etc...help please
Hybrid View
    Dec 2006
    Default Memory card, laptop, programer, etc...help please
    I just got my EFI v2 for my LBZ. I haven't gotten my laptop yet. The programer takes a memory card. What is this for? I thought I had to have a laptop to change programs.
    Can I store programs on the memory card and change without a laptop?
    How many megs should a memory card be to hold about 7 programs?
    If the programer can hold several tunes, data log, and read and erase trouble codes, they why the need for a laptop? Can a desktop computer do the tune, save to memory card, then use programer to load and change tunes?
    Feb 2007
    Yes you will not need a laptop at a later date. Suposed to be out 1st quarter 2007. I would atleast get a 1 gig card.
    Sep 2005
    The memory card is for future function of stand alone flashing, reading and logging that are supposed to be coming shortly. It will recognize up to a 2 gig SD card, but they say a 512meg will hold enough mem to log 24/7 for a week and several hundred tunes .
    To give you an idea on file size, your LBZ tune file is only 2 Megs, and a 1 hour log might be around a meg or a little over, depending on the data rate and the number of PIDs your monitoring
    Dec 2006
    Thanks, I'll get a 512. Guess the EFI is sort of useless for a couple days till laptop comes in. Thus far, I can read and clear codes only.
    Dec 2006
    Well, found a 2Gb at Wally world for $29. Guess you can't have too much.
  1. Internal Memory
    By Goldfinger911 in forum FlashScan V2
    Last Post: October 15th, 2008, 06:38 PM
  2. Flash memory programming.
    By rally1 in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 07:44 PM
  3. ? about Memory card for V2
    By DuramaxPowered in forum FlashScan V2
    Last Post: February 26th, 2007, 03:30 PM
  4. Memory dump VS Commodore
    By vsboost in forum EFILive V4
    Last Post: March 11th, 2006, 03:39 PM
