Results 1 to 5 of 5
Thread: operating system
    Dec 2006
    Default operating system
    im a new user to efi live and can really only do basic stuff (for now). anyway, i have a 99 T/A manual. in about a month i am going to be installing an ls6 intake, headers, an airlid, and an 85mm granatelli zo6 maf. i was looking at the stock tunes at holdencrazy and was wondering what OS i should download to have a starting point with. i figured an 01-02 OS. i was looking at downloading the 02 vette z06 manual stock tune. i figured since it has a 85mm maf and an ls6 intake. not sure if it will work since it is an ls6 and i have an ls1. like i said im new to this but would like any input to help me.
    Oct 2004
    Most people will go straight to the 2002 OS which is 12212156. There is a stock tune on the repository for that
    Remember to change the injector tables if you are going to continue to run your 26lb's (from memory the 99's have those).
    Andrew
    EFILive Crew
    You must use an F-body base tune, don't use the Z06 one.
    Jan 2005
    I believe there is a manual and automatic '99 fbody to migrated to '02 fbody on holden crazy you can use as your base.
    Dec 2006
    thanks guys. probably gonna have more Q's later
  1. 09 lmm operating system
    By 07.5duramax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 11th, 2009, 11:59 AM
  2. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 11:58 AM
  3. wrong operating system?
    By HighPSI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 01:08 PM
  4. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 03:50 PM
