any idea why idle ltft go high 20 + after auto ve tune every one i do has done that.they are all with cams 224 @.050 or bigger that i have done.seem to run same with or with out high ltft after i reset them.
Did you re-enable the MAF? If you AutoVE in SD and then re-enable the MAF with the stock MAF table, it'll be lean and you'll need to tune the values in the MAF table.
on this one i re-enabled the maf then maped it so i could auto tune it also
If you tuned the VE and the MAF, then it might be faulty O2's.
