Thread: 2-3 not shifting
    Oct 2005
    Default 2-3 not shifting
    o.k.,
    2002 Holden Camador ( Lumina ) 5.7L
    All shifting points are fine except the 2nd to 3rd :(
    It doesn't shift tell it hits the Rev Limiter !!!
    I even put the Rev Limiter at 7200 and the shifting point at 6400. Yet it doesn't shift with WOT and it hits 7200.
    I have to take my foot from the pedal so it will shift and then repress.
    I have also changed the shifting solenoid thinking it was not good but no luck :(
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Check where your 3-2 downshift is set at.
    Post your tune so people can look at it.
    Dave.
    Oct 2005
    Sorry and thanks
    Assami,
    Reduce the 2-3 WOT MPH (and also set 3-2 WOT MPH to be below that) to say 50 MPH, and see if you get the shift;
    if yes, then increment to 55 and test again (and continue to 60, 65);
    if no, then reduce the 2-3 WOT RPM to 5000 and test again;
    At all times: keep the 3-2 WOT MPH at least 5 MPH below the 2-3 WOT MPH.
    I would also suggest setting all the Kickdown Throttle settings to 100%.
    Junior Member billiardcue's Avatar
    Jan 2005
    Assami,
    Is this also true for the 1-2 and 2-1 shift settings?
    Dick Abbott
    Quote Originally Posted by billiardcue
    Yes, same method applies for 1-2 and 2-1.
  1. 4x4 shifting
    By southern in forum Gen III V8 Specific
    Last Post: May 18th, 2010, 11:13 PM
  2. Trans not shifting at WOT
    By acsf in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 9th, 2009, 01:34 AM
  3. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 06:34 PM
  4. LS1 PCM Performance shifting
    By Cougar281 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 02:31 PM
  5. Sloppy Shifting H2
    By dfe1 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2005, 04:17 AM
