Results 1 to 10 of 14
Thread: LS2 GTO L92/L76 swap
    Feb 2007
    Default LS2 GTO L92/L76 swap
    Newbie to forum and EFILive, looking for info on correcting injector size in 2006 GTO with L92 head/L76 intake swap. I believe stock injectors are 33lb units and all the info I have found states L76 intake delivered with the new 2007 Z06 40 lb injector, can anyone confirm this info?
    Also were in the tune software do I change the injector sizing? Is it Injector Flow Base?
    Any help or guidance would be greatly appreciated.
    Rob
    Welcome to the forum!
    The stock injector for the LS7 are rated at 40 lbs/hr. Not sure of the L76 injectors.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    EFILive Distributor dfe1's Avatar
    Jan 2005
    In the LS2 world, Injector Flow Base is the injector flow rate-- table B1215. Keep in mind that these rates for systems with a pressure regulator that is not referenced to manifold pressure. If you change the fuel system and incorporate an aftermarket pressure regulator, there's no need to scale flow rate. Also, you can build a conversion table to display in pounds per hour. Copy the injector flow base table to the clipboard, click on Conversions in the main calibration window, the click "Create New Table" and convert from grams per second to pounds per hour.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Feb 2007
    Once I create this table, how do I plug in the correct numbers for the Z06 40lb injectors.
    Great info guys I thank you for the help.
    Rob
    Jan 2005
    If you create the table in lbs/hr, convert it to grams per second, then copy with labels and paste with labels into B1215. The values for 40-pound injectors are (in grams/second):
    Injector Flow Base (mg/ms)
    kPa Value
    0 5.040000
    5 5.071400
    10 5.102600
    15 5.133700
    20 5.164500
    25 5.195200
    30 5.225600
    35 5.255900
    40 5.286100
    45 5.316000
    50 5.345800
    55 5.375400
    60 5.404900
    65 5.434200
    70 5.463300
    75 5.492300
    80 5.521200
    In lbs./hr.
    0 40.000000
    5 40.249881
    10 40.497504
    15 40.744334
    20 40.988782
    25 41.232437
    30 41.473711
    35 41.714191
    40 41.953878
    45 42.191184
    50 42.427695
    55 42.662620
    60 42.896751
    65 43.129295
    70 43.360251
    75 43.590413
    80 43.819782
    678/344-1590
    Feb 2007
    Thanks, that worked great. The car starts and runs much better. Now when I start fine tuning air fuel do I use another table? Also when correcting for improved air flow do I adjust the VE table or is this done in another table?
    Thanks so much for the valuable advice I couldn't do this job without your help.
    Rob
    That site is pretty interesting, I just spent the last 30min checking it out. I have wanted to do an engine swap into an old school mid-70s C-body pickup. I have been thinking maybe an LS2 b/c it is easy to tune via EFILive, but the LQ9 has potential as well.
  1. pcm swap
    Last Post: August 18th, 2009, 07:10 AM
  2. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  3. 97-02 pcm swap ?
    By TurboVet in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 01:08 PM
  4. 01 to 03 ECM swap
    By sweetdiesel in forum General (Diesel)
    Last Post: January 3rd, 2008, 06:03 AM
  5. VIN swap
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 04:18 PM
