untill i learn all the tricks,
400=.87
800=.87
1200=.87
1600=.84
2000=.84
2400=.84
2800=.84
3200=.84
3600=.80
4000=.80
4400=.78
4800=.75
5200=.77
5600=.77
6000=.77
after that they all show .77 untill the end.
does this do any good?
400=.87
800=.87
1200=.87
1600=.84
2000=.84
2400=.84
2800=.84
3200=.84
3600=.80
4000=.80
4400=.78
4800=.75
5200=.77
5600=.77
6000=.77
2000 NBM trans am.
427 Dart ship block,Lme ported Ls7 heads 12.5 compression
246/262 .730/.712 112+4 low lash solid roller
Rmvb 4l80 with transbrake, 8" FTI converter
12 bolt Moser rear end with 4.10 gears
if divide stoich 14.62857 by .87 you get 16.81 that is the AFR you are commading for pe you should be closerOriginally Posted by dc_justin
2002 ws6 stock short block
GMPP cnc LS6 Heads 11.4:1 cr
.576 i .581 e 116 lobe
D1SC @ 10#
723 rwhp 654 rwtq on E-85
It looks like you're viewing AFR in Lambda.Originally Posted by Aint Skeered
Lambda = AFR / Stoich
Conversely, AFR = Lambda x Stoich. At 4800rpms, your PE mode fueling is commanding 11:1 AFR
is there a way to make it read afr instead of lambda?
2000 NBM trans am.
never mind. edit>properties done it.
should i put it set to 12.7 across the board?
2000 NBM trans am.
also, what about setting pe to come in at 3000? is that about right ? lower or higher?
2000 NBM trans am.
65% TP below 3000 and 35% TP above 3000 should be ok...
where are you talking about 65% below 3000 and 35 % above? what area? you lost me. b3616 maybe?
2000 NBM trans am.
i am showing in the b3616 to come in at 90%. is that where you move to 65%- 30%?
2000 NBM trans am.
