Results 1 to 2 of 2
Thread: Boost pressure input and logging
    Jan 2007
    Default Boost pressure input and logging
    How is everyone logging boost pressure? I am running 13-14psi at the moment on the OEM OS in my Z06 and I don't have a 2 or 3 bar sensor anywhere on the car. Since it's a turbo app, I need to log boost throughout the RPM range instead of just looking at peak boost.
    Edit, also, since I am running 13-14psi and may even go as high as 15psi, I am assuming a 3 bar is probably the right path to go, especially if I want to be able to detect any sort of top end boost creep. I've used the sensor on this order page before with their controller/data logger and it seemed to work well and has a big pressure range, but it's a bit pricey. http://www.zeitronix.com/order/order.htm Any ideas are welcome
    Jan 2005
    From the scan or tune tool, click Help -> Tutorials -> Custom OS Tutorial. There is a section in there about setting up 2-3 bar map sensors.
  1. Replies: 2
    Last Post: September 17th, 2008, 01:51 AM
  2. Fuel Pressure input
    By Beer99C5 in forum External A/D inputs
    Last Post: December 23rd, 2007, 11:44 AM
  3. LB7 Oil Pressure logging
    Last Post: December 7th, 2007, 05:22 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 11:56 AM
