Does anyone have a part number for the 3 bar GM map sensor to suit LS1
12223861
Type this number into part No search at http://www.gmpartsdirect.com
and you will get a picture and details.
Just double check its the one you want (I'm not 100% certain)
Dave.
Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
Yep, I got the number right by the looksOriginally Posted by purrvert
Dave.
The one I have here is - 16040749, looks the same as the one shown on GM Parts Direct.
If you read under the picture it says its the same as 16040749 (older) but it has a different plug and a harness adapter needs to be bought (to adapt to which car I don't know)Originally Posted by GMPX
Ross, if 16040749 plugs into ls1 harness I guess the other needs that adapter
Dave.
Thats the old style ( I have them in stock for the older Delco's ) was looking for the direct bolt in version for the LS1 like the 12580698 2 bar LS1 sensorOriginally Posted by Biggsy
None of those numbers will plug into a LS1 , they all take the old delco connectorsOriginally Posted by Biggsy
Oops, sorry I should have studied the picture a bit better
Dave.
