Results 1 to 2 of 2
Thread: RPM activated Electric Cut Outs
    Junior Member JET LEE's Avatar
    Jan 2007
    Default RPM activated Electric Cut Outs
    I was reading about a QTEC controller that can control the position of electric cutouts. It also says it has automatic open or close by grounding or not grounding the trigger wire. Has anyone wired one of these into the pcm controlled it by rpm?
    Could you theoretically do this in the same manner as the recent shift light post by setting the rpm at which you wanted them to open? Of course, you would have to give up the shift light.
    Thanks.
    1 7/8" American Racing Headers, 3" X pipe, 6" GHL Bullits ~ DONE, AEM Wideband~DONE, MTI R1 Cam~DONE, Mototron 60's~DONE, D1SC Stage II procharger~DONE, Alky Control Methanol Spray System~To do
    Jul 2005
    It takes approx 3-5 seconds to fully open the cutouts, then the signal would have to be removed or you will burn out the motors. You could possibly use the shift light for trigger but would need an external timer.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
  1. looking for pcm pin outs and wiring diagram
    By mvvette97 in forum Gen III V8 Specific
    Last Post: February 6th, 2010, 06:03 PM
  2. Electric Fan Control
    By epb091786 in forum Duramax LB7
    Last Post: June 8th, 2009, 02:35 PM
  3. Electric Fan Problems using pin 33
    By chevy052500hd in forum Gen III V8 Specific
    Last Post: June 6th, 2009, 08:06 AM
  4. Ins and outs for MPG tunes
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 31st, 2009, 03:53 PM
  5. ecm pin outs
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: January 7th, 2006, 04:05 AM
