Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Rocketman69, look in here for LS2 GTO HO2S connections...
    Default Rocketman69, look in here for LS2 GTO HO2S connections...
    Gib,
    I couldn't attach files to the pm I sent you, so here are those attachments...
    This is for 2005 GTO.
    The HO2S plug is a little different, it has 2 keyways on it, see the pic.
    Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1
    Connector Part Information
    9723-6897-40
    4-Way F (GY)
    Pin
    Wire Color
    Circuit No.
    Function
    A
    BU/BK
    1664
    HO2S Low Signal Bank 1 Sensor 1
    B
    PU
    1665
    HO2S High Signal Bank 1 Sensor 1
    C
    BK/WH
    1050
    HO2S Bank 1 Sensor 1 Heater Low Control
    D
    PK
    439
    Ignition 1 Voltage
    Gib,
    You may not be able to power your LC-1 from the HO2S connectors because the PCM controls the heater power, as you can see in the wire diagram;
    maybe the PCM switches heater power on and keeps it on, I don't really know... you could test that with a DMM, and if id does keep the heater power on, then you should be ok.
    Cheers
    Joe
    Junior Member Rocketman69's Avatar
    Dec 2006
    Thanks Joe! That's exactly what I've been looking for.
    -Gib
    Dec 2006
    Gib,
    So what controls the heater power on the LS1 cars?
    -Gib
    Quote Originally Posted by Rocketman69
    On F-body LS1, it is controlled by the ignition relay via the ENG SENSOR fuse, so it's direct.
    Dec 2006
    ah....I see. So the heater circuit on the LS1 cars isn't monitored by the PCM at all....I believe we get a code if the heater circuit doesn't read any voltage at the PCM.
    -Gib
    That leads me to believe the PCM possibly just keeps heater power on all the time (and why wouldn't it, it wants feedback from the O2 sensors).
    Feb 2007
    Gib,
    Cheers
    Joe
    Hi Joe, another post from the dead, how about this possible issue, was it resolved? How would the PCM control the heater power thru the ground wire?
    Quote Originally Posted by Gelf VXR View Post
    Hi Gelf,
    The 4th Gen F-cars powered the NBO2 heater via a relay that come on with key on, and the heater ground goes directly to chassis/battery ground... so trying to power a wideband from here is not a problem (as long as all the wiring and terminal crimps are in good condition, i.e. no voltage drops).
    The GTOs on the other hand have the NBO2 heater ground going to the PCM, and we found that the PCM controls heater current/temperature by doing PWM on the heater ground... so trying to power a wideband from the NBO2 connector does not work due to repeated interruption of ground.
    Feb 2007
    I have a vauxhall monaro, similar/same E40 PCM as the GTO. Ive had the LC-1's wire to the PCM heater and ground since day one, the LC-1s seemed to work fine, never reported any errors, but im sure the grounds must have affected the response and accuracy.
