Originally Posted by
SSpdDmon
The problem I see with this manner of doing things though is the PCM is running off of the backup VE in SD, right? So, if it's interpolating, it's doing so from the 50kPa column to the 60kPA column in the backup VE table. The 55kPa column (as seen in the primary VE) is assumed to be a certain value based on what's around it in the backup and no attention is paid to the 55kPa value in the primary VE. So, I say just log the backup and get that as close as possible. Then, copy/paste the *0kPa columns over to the primary VE when finished and hand smooth out the *5kPa columns. Once the MAF is re-enabled and tuned, it won't make that much of a difference.
