I apologize if this has been covered elsewhere, but I can't seem to know the right search terms to find the answer to my question.
When the 5-tune switch feature becomes available for the LBZ (notice I said when, not if ) will it maintain separate shift table info for each tune? For example, if I'm running a 500 hp tune for a few months and then go back to stock to tow a heavy load, will my shifts be slamming between gears until the transmission learns all over again or will the tables be swapped out for the lower pressure shifts needed for the stock tune?
Thanks,
Shawn
