Results 1 to 7 of 7
Thread: Anyone disconnected their front O2's after open loop programming?
    Default Anyone disconnected their front O2's after open loop programming?
    With B3801 disabled, B4205 maxed, Commanded table set other than 1.0, any reason to keep the front O2's plugged into the harness?
    Jun 2005
    As long as commanded fuel in open loop & PE are set to your liking and your WBO2 matches what's commanded, I'd say you can get rid of them. I'd recommend keeping an eye on it with the WBO2 as there will be some variation in fueling as the operating environment changes. But, you should be fine. Don't forget to kill ALL of the NBO2 related DTC's in C6001 too.
    Jan 2004
    I haven't had O2's on my car for 3 years now.
    Jan 2005
    !NB's for about 2 years now.
    Jan 2005
    Quote Originally Posted by onfire
    The only reason is to keep the connectors clean. If you want to unplug them, I'd recommend removing the sensors completely and installing plugs in the bungs, then find some connectors, block the terminal openings and plug them into the harness connectors. That way if you ever need to go reinstall the O2s, you'll have usable connectors.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Thanks for the replies!
    They're off the car and it's running fine OL COS5 Thanks to a bunch of help from CHAD!
    Jan 2004
    Glad it all worked out for you.
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 02:37 AM
  2. program is changing open loop to close loop
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2007, 05:38 AM
  3. Open loop or semi open loop still?
    Last Post: October 18th, 2007, 02:46 AM
  4. closed loop and open loop switching
    Last Post: July 10th, 2006, 07:56 PM
  5. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 04:25 AM
