Ok. Got most of it working!
Voltage is with .01+/-!
Now figure this out....
The voltage at the AD1 input is bang on. I confirmed this by using both the LM-1 and LC-1 pids
At 1.59 volts the LM1- pid was at 15.9 (EXT.AD1)*10
0 volts=10.1
5 volts=30.1
At 1.59 volts the LC-1 pid was at 12.12 (EXT.AD1*3)+7.35
0 volts=10.1
5 volts=20.1
BUT the Autronics pid (which I need from the dyno) was showing 14.3 when it should be 16.36!
I checked the pid calc in the generic folder and was wondering why if the range is;
0 volts=10.1 and 5 volts=30.1 why the pid should not be the same as the LM-1? Its all relative to voltage input isn't it? The formula is (EXT.AD1*4)+10
Almost back to where I was!
Thanks guys!
Howard
