Anyone clarify wiring diagram with SM-AFR?
The connector for the WB linear output has 4 outlets.
1: 3.3v
2: Grnd
3: WB
4: NB
1: As I understand it, the 3.3v will run to ADR1 in EFILive.
2: Will be the ground that goes to the ADR1 ground in EFILive.
3: I am using the WB obviously but there is no additional wires. The wide band connector plugs directly into the back of the SM-AFR
4: I will not be using NB monitoring.
Am I on the right path here?
TIA.
