Results 1 to 5 of 5
Thread: Need help. Trying to read ls1edit file with efilive
    Sep 2005
    Default Need help. Trying to read ls1edit file with efilive
    Ok guys I really need some help. I recently had my car tuned with Ls1Edit. The tuner gave me my 2 tunes on a cd. One NA and my nitrous tune. I have EFI Live. I thought it could read LS1edit files?? Its not letting me open them at all. Can anyone help me out??? Do I have any options?? Please lemme know. Thanks
    Brian
    Just read the PCM, LS1Edit doesn't lock the PCM from being read with EFILive.
    You can load the LS1Edit files off the PC though, they use an LS1Edit only file format.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Hi Brian,
    Like Ross said, the only way you are going to be able to read those tunes in EFILIVE is to read them off the PCM
    The only way to get both your tunes into EFILIVE is to have your tuner cooperate with you (looks like he will if he gave the tunes on disk)
    Read your current tune off your PCM and save it, go back to your tuner and get him to put the NA tune back o your PCM. Read that tune off your PCM and save.You will then have both tunes in EFILIVE and you will be able to write the first tune back onto your PCM.
    Dave.
    Quote Originally Posted by BrianC98Z28
    Brian
    You cant read the .ls1 files that he would have supplied on disk with flashscan as they are encryted but you can read the tune out of the PCM.
    Just connect your flashscan cable up to the car and suck the tune out.
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    As far as a stock tune, you can get that from the library that is linked on this site of "stock" stuff.
    Located in Sticky here: http://www.efiforum.iqd.co.nz/showthread.php?t=2905
    So, suck out the tune currently in the PCM and then download the stock tune from the thread and you have the 2 tunes (assuming the CD contains "stock" & "current").
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
  1. Anyway to read a HPT file?
    By turboolds in forum FlashScan V2
    Last Post: December 16th, 2008, 08:17 PM
  2. logged file can't read
    By knagel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 22nd, 2008, 01:27 PM
  3. Replies: 12
    Last Post: July 23rd, 2007, 04:44 AM
  4. Convert LS1Edit File to EFILive ... Help!
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2006, 03:00 PM
  5. How to read Ls1edit files???
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2005, 06:56 PM
