Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: EGT K type Thermocouple Probe
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default EGT K type Thermocouple Probe
    What are the benefits of logging EGT? Is it worth the trouble for self tuning on a daily Driver (ocassional Nitrous spray?) or is it overkill?
    Is this compatable with V1?
    Product: #Caspers 103301 - EGT K type Thermocouple Probe
    Price: $59.95
    Category: PCM & Electrical
    Availability: In Stock
    Manufacturer: Caspers Electronics
    Weight: 2.00
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Lifetime Member Doc's Avatar
    Oct 2005
    Yes it will work with V1. Not sure of the benefit for a gasser that already employs a WBO2. Definetly a must for the diesel crowd. Maybe somebody more knowledgeable will pipe in. Bump for ya.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jan 2007
    I am not the greatest historian but I think EGT was the affordable/more possible option before WB came on the market. Maybe that is why it has such hold.
    I wonder why it seems airplanes use EGT and not WB?
    Quote Originally Posted by 2002_z28_six_speed
    same reason the TD crowd does. To protect the turbine.
    Custom Tuning Services
    Oct 2007
    Aviation fuel for piston engine aircraft still contains lead.
    Jan 2007
    Quote Originally Posted by Meghan
    Aww! I see. I know turbines need to watch core temps: Pin 3701 (CRJ200) from a couple years ago.
    But I was orginally referring to piston aircraft. You nailed it though. Thank you for your response.
    I know on outboards EGTs are used to dial in tuning, dont think there's a feasible way to get a WBO2 in one of them! lol
    Dec 2007
    Everyone thinks EGT when talking about Thermocouples (TC), but don't forget that a K type TC can accurately measure temperature ranges from below -200°C to above 1200°C. This means that you can basically use them for any temperature you want to measure in your vehicle. Depending on the type of probe end you use you can even get fast response in IAT or CHT.
    Personally I don't waste my TC's on EGT since I run a WB02, however I almost always have more than a few located before and after the intercooler and before and after the compressor (supercharger).
    Mind you given unlimited resources I would run at least 1 EGT after a Turbo or 1 at each exhaust port if supercharged.
    The point is EGT may not be important for most of us with a WB02, but having the ability to record temperatures can be an invaluable tuning tool for hashing out the thermal performance of any system.
    Jan 2007
    You are correct and I have actually be experimenting with just that.
    When I was having trouble with my IAT I used a thermocouple to compare the IAT sensor against another sensor to see if underhood temps were really getting that hot AND where could I move a sensor to get less error.
    GOOD POST!
    Jul 2005
    six speed, which type of thermocouple did you use for the IAT comparison? i'm in the market for few of them currently...
  1. EGT Thermocouple Question
    By chevyspy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 17th, 2007, 10:33 AM
  2. thermocouple not working when in manifold
    By kyle03d in forum Diesel
    Last Post: August 14th, 2007, 01:44 AM
  3. Thermocouple input thread
    By Drake in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2005, 04:22 AM
