Results 1 to 10 of 11
Thread: 408 with 90/90 wont start
    Jan 2006
    Default 408 with 90/90 wont start
    I have a 408 with a fast 90/90 setup and a good size cam. I can't get the car to start without giving it gas. I can't get it to idle either. I have tuned 402's before and never had a problem. The IAC is really high on also. I have added to the ve from 1200 on down,I have tried subtracting from the ve with no luck. Im lost.
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Try setting B4604 to something similar to:
    275.000000
    275.000000
    275.000000
    275.000000
    240.039063
    205.078125
    175.000000
    150.000000
    150.000000
    150.000000
    Between that, and desired airflow, that should get it starting pretty good, at least it worked for me on the last 408 I did which had a Victor Jr. and Edelbrock 4bbl.TB.
    Jan 2006
    That helped some. The IAC is at 175 at around 1000 rpm. There is something also weird going on with the TPS. I can move the gas pedal a petty good ways before it the tps changes. It seems slow to respond. I have messed with the idle screw also.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Maybe reset your TPS sensor for a start. Disconnect it and key on (dont start the car) and then wait and reconnect it. This might help the slow to respond issue.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Jan 2006
    Found one problem, bad tps. Just put a new one on will mess with it tommorrow. Being the 90TB blade has been messed with so much, by the owner and then by me can I set the new one up to factory specs by voltage? I dont have it in front of me, but isnt it supposed to read live .55 volts or something at 0% throttle?
    Oct 2003
    This does't have a LS2 cam sensor does it?
    Jan 2006
    Quote Originally Posted by Bruce Melton
    Not that I know of, but I will check tonight, Im 99% sure its ls1.
    Oct 2003
    It makes sense that it is LS1 but the way it is running is similar to the common reversed cam sensor lead on LS2s.
    PowrMax Performance
    100 mm PowrMAF
    Feb 2006
    If the iac is at 170 then open the TB alot more via the screw. You can set the idle limit to 2% or so.
    Jan 2006
    Quote Originally Posted by slowhawk
    If I open it more then the car will start but it idles at 1500rpms and wont go down. I have not tried this since I installed the new tps sensor however.
  1. wont idle at start up
    Last Post: May 9th, 2009, 04:56 PM
  2. wont cold start
    By dlove in forum Gen III V8 Specific
    Last Post: October 21st, 2008, 01:30 PM
  3. Car wont' start, need some help!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 10:08 PM
  4. New RR wont start the car
    By ntae in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 18th, 2007, 08:45 PM
  5. car wont start with COS#5
    By articSS in forum Custom Operating Systems
    Last Post: September 19th, 2007, 12:43 PM
