Results 1 to 7 of 7
Thread: 1:50,75 AFR-- no knock ??
    Dec 2006
    Default 1:50,75 AFR-- no knock ??
    My first scan is very disappointing.C6 6Speed. 2 questions about it .
    I captured an OL Drive 1st gear 48%TP showing 50,75:1 for AFR at 0,872
    and 0.885 Volts.spark 28.5 KR is only 0.6. How can this be … no knocking this lean.
    This around 50 value appears also with lover rpm during acceIleration.
    I installed a catback before I had the Scan tool.
    So i rely on novice guessing. Is this possible by less backpressure only ?.
    Second finding, bank 1 and 2 long term fuel trims are simular distributed
    over almost all cells, but 5% apart . Looks like a different head.
    The ltft #s tend to be positive, the car runs lean, okay…. But it is very fast, maybe
    It could be fast already driving 200 Km/h an then accellerating.
    Any ideas …
    Greetings from Wiesbaden
    GV,
    Welcome to the forum...
    Which wideband oxygen sensor do you have...?
    Cheers
    Joe
    Dec 2006
    Hi Joe ,
    your question is my answer. I don’t have anything other than the O2 sensors.
    That means it only makes sense to look for the voltage not for the calculated
    AFR-.. does it ?
    What do you think about the bank difference. Is 4-5 % less over all LTFT cell
    Within the normal rage.? It there a way to trim that anyway?
    GV,
    Oh, I see, you have the narrow band O2 sensors...
    So 50.75 is the commanded AFR....!?
    That is very strange.
    The LTFT1 and LTFT2 being 4-5% different may be due to an air leak on one bank, or something else.
    What are your LTFT's...?
    You can trim LTFT's by modifying the VE table B0101 and/or the IFR table B4001,
    but this trimming will not make LTFT1 and LTFT2 equal each other.
    You want the LTFT cells to approach 0%, and at WOT you want 920mV or a little higher.
    But... without a wideband sensor you cannot see what is the actual AFR.
    If you have a log, include a picture using this procedure (post #1 or #2): showthread.php?t=3064
    Cheers
    Joe
    Dec 2006
    Hi Joe ,
    I still don’t know what to do about it, but I understand the data now.
    If I play the log watching the LTFT table gets filled I see a quick jump to
    the right side, high maps and the cells get filled downwards according
    the refs .When I shift a quick jump to the left with high values typically 13,3%
    for 15, 20 25 cells.
    So maybe this electronic throddle ( I do what I like ) pids rule here.
    The other bank then reads 10,9% or so. The difference looks worse then it is.
    And its’s in red , you know. That helps to be a little shocked.
    I will scan more specific, its fun.better than a videogame. :-))
    P.S. there is no VE table in V2, maybe this will be an upgrade
    Hi GV,
    So left bank reads 13.3% and right reads to 10.9%... that's a difference of 2.4%... that is small and is ok.
    Yes, it is much better than a video game...
    C6 Corvette may not have a VE table in the PCM... but I'm not sure of this.
    Joe
    Dec 2006
    You get these high AFR Value if you scan LS2 with the GM.AFR_1 Pid.
    a swap to GM.AFR_B_1 will make a almost fixed 14,7 and in open loop
    you see 11,5 to 13 which makes more sense although it is no replacement
    for a wideband.
  1. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  2. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 10:07 PM
  3. Knock knock.... who's there? KR
    By Whippled 496 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 24th, 2006, 10:59 PM
  4. Got Knock
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2005, 06:29 AM
  5. Can't get rid of knock
    By jsttry in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2005, 12:56 AM
