Results 1 to 6 of 6
Thread: Tow/Haul mode?
    Lifetime Member N0DIH's Avatar
    Jan 2006
    Default Tow/Haul mode?
    How do I wire up a switch on the economy/normal shift tables so I can setup a Tow/Haul mode?
    Anyone know the pinout for it? Did any cars/trucks with this VCM use it?
    Feb 2006
    what kind of vehicle are you doing this on? There is a D3601 box to enable it . There are several ways to choose the shift pattern D0409 with what pin and how it is activated is explained in the description.
    AL
    Jan 2006
    I have a 99 K2500 454 Suburban that could benefit from it nicely.
    It seems there is an economy and normal shift tables, but how do I trigger it?
    I would also like to do it on a 98 Suburban K1500 350 too.
    Aug 2004
    Yes it works, you just have to fill in tons of tables. then just run a ground to a switch and the pcm imput.
    Jan 2006
    What PCM pin do I need to ground?
    Jan 2006
    Anyone know what pin I need to ground to activate the alternate shift tables?
  1. tow/haul mode?
    By THEFERMANATOR in forum Conversions / Aftermarket Parts
    Last Post: February 3rd, 2010, 06:43 PM
  2. Tow/haul mode
    By rennoc442 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 21st, 2009, 07:31 AM
  3. Lock Up in Tow/Haul mode?
    By coryhussey in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 22nd, 2008, 08:45 AM
  4. 98 5.7l Vortec Tow/Haul Mode...is it possible?
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 09:03 AM
  5. Tow/Haul Mode
    By 87gmc in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 19th, 2005, 10:54 AM
