And that inherently will introduce problems with an unreferenced regulator in boost. PCM thinks fuel pressure differential is static, yet 6 psi of boost yields 6psi lower differential fuel pressure than a N/A vehicle. On a set of Mototron 60s (63.2# at 43.5psi, 72.3# at 58psi), the PCM will think you're flowing 72.3# (0kPa MANVAC), when in reality, at 6psi of boost, they flow 68.5# or so, yielding lower than needed pulse widths and a leaner mixture...Originally Posted by joecar
