No. K&N cold air intake.Originally Posted by tunedbyGM
Originally Posted by dfe1
When I go back to closed loop SD I get -LTFT's and BEN's <1. This is what I would expect with the VE table scaled up from stock. Can anyone find a problem with the way I set up the AutoVE tune?
Problem Solved!
After some searching in the tune file I found parameter B4206 "Use O2 With Open Loop Commanded Fuel Table". This parameter was enabled on my stock tune. I disabled it and went out for a drive. BEN's in the 0.95 range, right where I expected them to be.
Maybe disabling B4206 should be added to the auto ve tutorial for people like me who have that parameter enabled on their stock tunes.
P.S. Thank you to those who repiled to this thread.
Great , I took a look (like I know anything) at the tune file did not see anything unusual , I did notice that the BEN for the LC-1 across the top you have the values in Metric , I did mine in Imperial which the values are 15-105 MAP , but I have Imperial values through out the Tuning software .
2006 Trailblazer
