Results 1 to 9 of 9
Thread: V7.2.1 pre-release is publicly available
    Default V7.2.1 pre-release is publicly available
    Enhancements listed here:
    http://www.efilive.com/downloads/v72_updates.html
    (This list was updated May 08, 2005.)
    Download here:
    http://www.efilive.com/downloads/downloads_7.html#V721
    Updated documentation is included.
    This version will most likely go to CD production on Monday.
    Reports of any spelling mistakes or other annoying but easily fixed (i.e. cosmetic) issues are most welcome, up until Sunday night (May 09).
    Jan 2004
    Sounds good. I should be placing my order for FlashScan sometime today. I can't wait to finally get it.
    Mar 2005
    Have the default dashboards been accidentally excluded from the v7.2.1 install? Just tried installing the new pre-release on two separate computers that have both the default and customised dashboards.
    The new 7.2.1 install removed the Default folder and default imperial/metric VDP files from My Documents\efilive\v7\VDash. If I restore my backed up copy of the VDash directory all the default dashboards work again.
    Oct 2003
    DTCs are now cleared following a PCM reflash or read. No more loading the Scan Tool just to clear communication trouble codes set during the reflash or read process.
    Great feature!
    It's the little things.
    Thank you.
    joel
    Quote Originally Posted by jsttry
    In the V7.2.1 release the existing dashboards are removed. Then new ones are installed. I do not know why the new ones would not be installed.
    I will investigate here.
    Meanwhile copying them from backup is a good solution.
    You should als be able to re-run the install and select [Repair] to force the installer to update all files that are missing.
    Jun 2003
    That works, same thing happened to me and the repair put all the files down.
    Lifetime Member SS2win's Avatar
    Feb 2005
    same thing here and there was no manuals installed. ran repair and all is good.
    2001 Camaro SS
    EFILive Custom OS3
    Sep 2003
    Same thing here....after first time through the install no dash...reran and all is OK????
    Mar 2005
    Did the same to me... Loaded program no dashboards.... unistalled and then reinstalled 7.2.1 everthing is fine.
  1. EFI not same release as V2?
    By RPM Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2008, 05:57 PM
  2. Pre release 7.5.1
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2007, 08:55 PM
  3. New release 533
    By eboggs_jkvl in forum FlashScan V2
    Last Post: July 12th, 2007, 02:34 AM
  4. V7.1.9 Pre-release is now available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2005, 02:47 PM
