I just replaced my LS1 motor with an LS7,So far everything is fine,But it takes to long to start.It cranks for a few seconds then starts.What can I adjust to fix that?.Thanks.................Paul
Hm ... getting a bit more detail might help ...
Congrats on the upgrade anyway!!
Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
Long cranks are losing your "pressure" in the fuel line. This causes the pump to have to reprime the line and then it starts. I had this when I went to an external fuel pump. I put in a check valve to hold pressure and it starts at the first fire of the plugs. Check your fuel pressure. IF it falls to 0, that is wrong. I should drop but halt and hold in the 40 PSI range
That would be my best uneducated guess.
Elmer
2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
You should listen to Elmer. He's had the Long Time to Get Started problem for a few decades.
2005/2007 DHRA Western Drag Champion
Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
Does it make a difference if you have the throttle cracked open a bit?
www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
Its holding pressure.When I turn the key on but don't start it the fuel pump comes on and the fuel pressure goes to about 55psi then drops to 40psi and holds there. On a cold start up it started right up first shot.I shut the car off and tried to start it again and it cranked a few times then started It sounds like its getting fuel and no spark for a few seconds.The reason I say that is because it sounds like a violent start,I have open header's right now and it scares the crap out of ya when it starts Thats the only way I can describe it.It does not backfire or anything.I pressed on the gas pedal a little,One time it started doing that and another time it just kept cranking.I have alot of tuning ahead of me that I know,I guess getting it to start is a good place to start ..............PaulOriginally Posted by eboggs_jkvl
I increased my Startup Friction Airflow Correction table to help a little with cold starts, but mostly for warm starts. After I would start it (warm), it would stumble for about 5~10 seconds before finding desired idle speeds. So for a quick fix, I increased the {B4343} table by 4 grams/sec across the board. No more issues on startup.
Do you have any DIC codes?
I am thinking CKP or cam sensor. I did exactly the same swap and had that problem related to the cam sensor wiring harness as discussed on the other forum--
PowrMax Performance
100 mm PowrMAF
Its funny you ask,I did get a P0343 CMP Sensor Circuit High Voltage.But I read in the service manual,At the end It says "A slightly longer cranking time may be a symptom of this condition" I did flop the cam sensor plug like K-tek suggested.What did you do to fix it.Also I pulled the plugs today and they were wet with gas.Whats CKP?I'm waiting for my header's to come in so I can take it for a test ride and see if this clear's up.I had 1 3/4 I'm going to 1 7/8.................PaulOriginally Posted by Bruce Melton
