Results 1 to 5 of 5
Thread: Reading the older IL4 PCM's
    Default Reading the older IL4 PCM's
    The reading and programming options have been in public beta for over a month now but many might not actually be aware of this.
    To ensure we get good coverage of all engine types used with this controller we request that you please send any .tun files you might read out of these PCM's to support@efilive.com
    You must be using V2 hardware to be able to read / program the In-Line 4cyl PCM's.
    When you press the green icon in Tune, select either the "97+ 4 Cylinder" option or "02+ 4 Cylinder" option from the drop down list. If you are unsure which PCM the vehicle is using try to locate the PCM in the engine bay and compare it to the picture shown at the top right of the read screen.
    If you select the wrong PCM type don't worry, you won't damage anything, the PCM will simply reject the bootloader and EFILive will give you an error message stating this.
    Select 97+ 4 Cylinder PCM to read:
    Select 02+ 4 Cylinder P11 PCM to read:
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Sweetness!!! THanks for the additional vehicle support guys.
    Nov 2007
    Using the latest EFILive release and my V2, I still received an 'unrecognized controller' error... any ideas?
    EDIT: This is on a 1997 S10, manual trans
    Aug 2004
    Rausche email me your bin file and i will send over a .cal for you. jessebubb@yahoo.com
    Nov 2007
    Thanks! You've got mail!
  1. older 4L60E with E38
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: January 8th, 2010, 02:06 AM
  2. possible to unlock 6th & 7th gear on older allison?
    By rubbersidedown in forum Allison 5 & 6 Speed
    Last Post: March 18th, 2009, 03:16 PM
  3. Using Flashscan V2 with LS1 Engine Swapped to Older Chassis
    By Mikey 97Z M6 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 06:55 AM
  4. Older OBD2 V6 support?
    By Telco in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2008, 01:49 AM
  5. Older Laptop
    By Anonymous in forum Purchase and Shipping
    Last Post: August 30th, 2005, 06:24 PM
