Assuming a 402 (C5 ETC) moving from 78mm/LS6 to a 90mm LS2TB/L76 setup what should be changed and maybe a starting value going in?
B4349 ETC throttle area conversion>?
B4403 IAC effective area>?
B4307 Desired airflow>?
Other>?
I have seen various attempts to calculate B4349 and they are all over the map from leave it alone @.0255 to .0157 to .0330.
Can someone point me in the right direction on the above?
Did this recently with a LS7 and am not sure my approach was from the proper starting point re. above values.
RAFIG scan values we half ~7 vs~3 in B4307.
IAC steps were maxed.
Desired airflow is really the air required to provide a AFR that works @ idle? Thus if you AutoVE the idle to run @14.7 then the Desired airflow is used to lean beyond the ~14.7 due to cam overlap?
When you enter the B4307 values will it go there absolutely or will other factors contribute to a commanded blend shown in RAFIG?
(engine specs in sig below)
Thanks,
Bruce
