Results 1 to 10 of 11
Thread: holden VY V6
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default holden VY V6
    Hi, I have a mate who would like his VY V6 commodore tuned after some engine/exhaust mods. Can anybody tell me what type of ECM/PCM/TCM are in this model as I believe they went to a flash style computer which is different to the earlier VT-VX. would this also be OBDII not OBDI. Can flashscan scan this vehicle & what software do people use to tune these?
    It's OBD-I and only used on Holdens. Sorry, you are out of luck, not even Kalmaker is going to touch it.
    Feb 2006
    Chipmaster does tuning on the VX,VY's but i believe it requires going back to a VT type computer. So requires wiring changes.
    Yes, I think you are correct there.
    They can be tuned, but, it involves pulling the flash off and programming it in an EPROM programmer, not really ideal at all.
    May 2005
    cheers, thanks for the replies fellas. I'll have to see how keen my mate is to get a tune.
    May 2005
    maybe Delco could chime in and tell us if it's possible or how to.
    Quote Originally Posted by limited cv8r
    STD VY PCM cant be done , it requires a computer change and rewire to a supercharged computer
    May 2005
    do you need an earlier model computer or a VY supercharged one?
    May 2005
    does it specifically need a supercharged computer or would an earlier ecotec computer work. What is the main reason for needing the supercharged computer if this is the only option?
    VY supercharged computer is required , different to the VY non supercharged or normal ecotec.
  1. Holden E38 Files
    By RonC in forum Gen IV V8 Specific
    Last Post: August 18th, 2022, 05:25 PM
  2. Holden V8 - reluctor 24x with LS1 PCM
    By Batman in forum Conversions / Aftermarket Parts
    Last Post: July 21st, 2009, 04:36 AM
  3. PE in HOLDEN VE L98
    By vessv73 in forum Gen IV V8 Specific
    Last Post: May 19th, 2009, 11:11 AM
  4. Holden VE which ECM?
    By ringram in forum Gen IV V8 Specific
    Last Post: March 5th, 2007, 07:39 AM
  5. DTC HOLDEN VS
    By vsboost in forum EFILive V4
    Last Post: October 14th, 2005, 03:24 PM
