Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: rev limiter
  1. #11
    Feb 2006
    Maybe it is a V8 issue? The two that didn't seem to have problems are 4.3 V6
    Al
  2. #12
    Aug 2004
    There is no real rev limit table in the pcm. You can see that clearly in the scan tool. It is a side effect caused by SPARK Coil DWELL. NOT an issue with FUEL.
    When i get time, i will try to put them in as soon as all the tables are found and then you can modify it to any limit under 8190. Just have a ton of other stuff going on right now so it might be a few weeks..
  1. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 10:53 AM
  2. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 12:28 PM
  3. '98 LS1 Rev Limiter...
    By TNTFEDZ in forum Gen III V8 Specific
    Last Post: May 12th, 2007, 11:48 AM
