Results 1 to 10 of 10
Thread: inside the 02+ L4 pcm
    Mar 2007
    Default inside the 02+ L4 pcm
    I got bored so i hacked open a 02+ L4 pcm from a chevy cavalier..
    perhaps this will help the guys from efilive also
    the processor is motorola 68k, the eprom intel 28F800 1mb.
    I will post the ECU flash content also..
    best regards,
    Bing.
ID:	1430   Click image for larger version.
ID:	1431   Click image for larger version.
ID:	1432   Click image for larger version.
ID:	1433   Click image for larger version.
    Mar 2007
    another picture...
    Mar 2007
    and finally the actual flash read from the chip...
    br
    bing.
    OMG, hacked is right, you sacrificed it!, you should have asked for some pics, I have one all apart here. Last I saw they were going for 75 cents on Ebay motors .
    Just an FYI, I downloaded the file, unzipped it, and tried to open it with EFILive. Says bad .bin file... Dont know if that just means I cant read it, or that the file is actually bad.
    But, those are some cool pics of the inside!
    Mar 2007
    thanks,
    the file posted is raw binary and cannot be loaded with efilive (only 5.7 V8 binary files can be loaded), and then can only be saved in efi live format, to protect their hard work
    bing.
    Actually, the real reason is they only used 512K of the 1Mb chip, so we strip out the upper half (it's all blank). If anyone has a hex editor just delete everything from $80000 up from that file posted (just after the $5AA5A5A5 data). Then the file will load, you can load any .bin file still as long as the software knows what it is (i.e, don't try loading a 2002 Volvo file ).
    Also, look at my accidental hacking effort when trying to remove an E67 from the case..........that would be the CPU sitting next to it. I was lifting the VERY thin PCB off the goo that sticks it down, heard a crack and knew it could not be a good thing.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Just solder pins back on, it'll be right!
    Dave.
    Well I tried loading the file after hex editing everything after that last string of data, and still I get a bad file format error (tried saving as .bin and .tun). Ohh, well, it was a fun way to blow 30min this thursday night.
    I'm having trouble modifying the file as well. The "flash chip" file ends at $34999. I'm also not seeing the $5AA5A5A5 string that GMPX is referring to.
    Could someone shed more light on this or upload a corrected file?
  1. Problem with V1--- Pics Inside...
    By nonnieselman in forum Lounge
    Last Post: November 2nd, 2007, 02:04 AM
  2. Need some help with a few issues: tune inside
    By Earl H in forum Custom Operating Systems
    Last Post: June 12th, 2007, 05:35 AM
  3. Anyone with a 90mm TB inside please
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 03:59 PM
  4. RAFIG Idle Users Inside
    By SUPRSLO in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2006, 10:46 PM
  5. OK so I am lazy. Script question inside
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2005, 07:57 AM
