Results 1 to 7 of 7
Thread: Connecting issues
    Apr 2005
    Default Connecting issues
    I am having connecting issues connecting to an 03 H2. I had a similar problem connecting with my corvette the first time. I unplugged the cables, restarted the software (a couple of times in a couple of different orders) and got it to work, from that point on, it connected first try every time. I haven't had any luck getting connected to the H2, the same laptop, cables etc... won't finish connecting to the H2. I get a couple of different errors. One says something about an invalid calibration...connecty anyway??? The other gets a bit further along in the connection process, it gives the 1 sec retry a few times, then holds for a bit, then I get bootloader rejected.
    Any ideas??
    Oct 2004
    FlashScan V1 or V2?
    What is the build of the Tune Tool? Go to 'Help->About' menu option to find this info.
    Do you have any issues using the Scan Tool and maintaining the connection?
    Andrew
    EFILive Crew
    Apr 2005
    It's V2, I can Scan and clear codes, no problem. It's 7.3.3 build 555
    Oct 2003
    I have that problem as well with V1 and V2. Sometimes I have to connect and reconnect the USB end every flash in order to reconnect. Sort of assume it is normal-
    PowrMax Performance
    100 mm PowrMAF
    Apr 2005
    Thing is, I can connect first try...everytime to my 2000 corvette (once it has been liscensed). I CANNOT connect to the H2 to liscense it....at all. Tried everything I could think of. I suspect, once it's liscensed it won't be a problem. It seems it has a problem "unlocking" the ecu.
    Hi Jason,
    After you get the failure on the H2, locate the most recent *.blx file in the folder My Documents\EFILive\V7\Bug Reports and send it to me at paul@efilive.com That should help me to identify the issue.
    Apr 2005
    Hi Jason,
    File sent! Thanks for the support!
    Jason.
  1. Connecting LC1 to V2
    By LSs1Power in forum FlashScan V2
    Last Post: August 6th, 2010, 10:56 AM
  2. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  3. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  4. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
