Results 1 to 4 of 4
Thread: Trying to use 4L60-E with 4-barrel carb
    Mar 2007
    Talking Trying to use 4L60-E with 4-barrel carb
    I have a 4L60-E automatic overdrive transmission that was originally
    hooked up to a throttle body 4.3L V6 chevy engine. I replaced the engine with a 350 with a Holley 4160-4-barrel carb. I would like to continue to use
    the original transmission. This transmission is electronically controlled
    and has no cable to "kick down" the transmission. I am told that the Holley carb will cause serious damage on electronic overdrive transmissions. I found one module from Jet that completely controls the transmission, but it was quite pricey. Do you know of any (under $1000) transmission control modules that will allow me to use a carb with the 4L60-E? Let me know, I'm dying to know. Other places I've checked (to no avail) are: Painless wiring and TCI.
    Thanks,
    Jim B.
    Mooresville, NC
    Could be tricky because most stand alone TCM's expect to see an ECM.
    The only other option is some of the earlier (80's/90's) Diesel engines used a stand alone TCM, but reprogramming them might be a problem.
    Dec 2005
    TCI does have a contoller, but it would require that you adapt a throttle position sensor to the carb...I believe they have kits for this as well, or at least someone makes them. The controllers are pricy though, almost $700
    http://www.tciauto.com/Products/Electronics/default.asp
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
    Dec 2005
    Just noticed the TPS adapter is at the bottom of that web page as well.
  1. 4L60 and shift kit
    By SRT10KLLR in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2013, 12:13 AM
  2. tuning carb intake and elbow
    Last Post: July 1st, 2008, 05:25 AM
  3. vz v6 4l60
    By zrx1200 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 21st, 2008, 11:09 AM
  4. 98 s10 converted to carb but still has 4l60
    By minytrker in forum Vortec V6/V8 Specific
    Last Post: August 30th, 2007, 01:39 PM
  5. 4l60 to mn6
    Last Post: March 5th, 2007, 07:33 PM
