Results 1 to 4 of 4
Thread: Change to Manual Trans with LBZ
    Mar 2007
    Default Change to Manual Trans with LBZ
    My ECM came from an Automatic transmission vehicle. I just downloaded the ECM memory and saved it as a stock.tun file. How can I change the settings so that it is changed from an Automatic to a manual transmission?
    Also, does anyone else have to the DTC section? I have a very limited amount of settings to adjust when I downloaded the memory.
    You will need to get hold of a tune from manual truck with the same options as yours. There is many underlying things in the tune that you don't see with EFILive that need to be transferred.
    The DTC section is not like the LB7 / LLY that you might be used too.
    At the moment we are including the most 'annoying' DTC controls, if you have a problem code let us know and we will look in to getting that included as well.
    Mar 2007
    Would I be able to take someone elses stock ECM .tun file and change the VIN to match mine then reflash the ECM?
    Yes sure, but, you really don't need to worry about the VIN, it's not that important (for EFILive) that it is correct.
  1. Trans Calibration, what to change...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: October 7th, 2011, 01:41 PM
  2. I need an stock E38 Manual trans Vette file!
    By Boostin99SS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2011, 07:25 AM
  3. Change From Auto To Manual, idle, stalling.
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2007, 06:43 AM
  4. How to change an auto calibration to a manual one?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:12 PM
